The Busted Bugeye - Page 2
Results 16 to 30 of 39
This is a discussion on The Busted Bugeye within the Builds forums, part of the Tech & Modifying & General Repairs category; Out with the old, in with the new.. Unfortunately my previous piston/block combination was not up to another build. So ...
            MainFrame's Avatar
    Austin, TX
    Unfortunately my previous piston/block combination was not up to another build. So I've picked up a new set of used case halves and am back down to a 99.54mm Arias piston this time. I'm sad to see the case go, but this will leave me with more meat on my cylinder walls.
    Heads ready for tear down.
    Goodbye ol' trusty.. hopefully you will find a new home with some new Darton sleeves.
    Crank still looks good.
    CP pistons are a little worn, but otherwise still on good condition. Not sure what I'm going to do with these now.
    Yep, she was burning oil in the chamber.. no doubt about it.
            MainFrame's Avatar
    Austin, TX
            MainFrame's Avatar
    Austin, TX
    Intake manifold swap..
    Giant intake is.. well, giant.
  6. #19
    Village Idiot McBill's Avatar
    Sep 2013
    Buckeye State
    Holy delayed update Batman!
    Billy
    2009 Ducati Monster 1100
    2008 Legacy 3.0R - SOLD
    2011 WRB WRX Sedan - SOLD
    Stink-Eye Mob #696
    Facebook
  7. #20
            MainFrame's Avatar
    Austin, TX
    Hot side FMIC pipe looks good.. can't get a much shorter route than that.
    Hashing out the new fuel system.. this is what I've got so far.
    *fixed the order
  8. #21
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Are fuel rails always plumbed in series (that's an honest question)? I guess it might not matter due to the cylinder firing order, I just figured they'd be in parallel.
    2007 Outback 3.0R wagon
  9. #22
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Fix your diagram!!
    (we talked about this )
    The cylinder IDs are wrong, and the plumbing needs to be reversed.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  10. #23
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by Rambo View Post
    Some people switch to parallel. The old school of thought was that parallel would be better, but it turns out it causes more issues, and doesn't fix any problems with running series, because evidently there are none.
  11. #24
    Oct 2010
    Portland, OR
    Yeah, I'm used to designing manifolds where equal pressure is critical across all ports, but my manifolds simultaneously fire all ports. Once I thought about the individual firing sequence, it makes sense that any pressure deviations between fuel rails would be resolved in the system before the next injector fired.
  12. #25
            MainFrame's Avatar
    Austin, TX
    And if you think about the pressure drop running away from the injector, then feeding in reverse firing order makes some sense too.. because by the time #4 is ready to fire again the last injector to have fired would be #1.. on the far side of the flow.
    I'm rethinking a few things after getting some input from Lance Lucas.. mainly my pump controller and the use of PTFE in the bay. Evidently a good rubber line will be better to use because it helps dampen injector pulses naturally, whereas PTFE is basically a hard line.
  13. #26
    zax
    zax is offline
    Nov 2008
    I understand the logic, but I'm not sure I agree. I'll have to think about this.
    Something something something fuel cavitation yada yada yada.
    Facebook me here
  14. #27
            MainFrame's Avatar
    Austin, TX
    Yeah.. I hadn't ever really thought about it before, but Lance Lucas told me not to use PTFE in the bay for that reason. I would guess he has some first hand experience with it.
    This is where I have ended up with the diagram.. ordering hose and fittings by the end of the week.
  15. #28
            MainFrame's Avatar
    Austin, TX
    Welder at the fabrication shop doesn't fool around. It's a nice change of pace from having the car sit at a shop litteraly a year or more before they even touch it..
  16. #29
    The Jedi Ninja TownLine500's Avatar
    Oct 2013
    Boston
    What are they fabricating for you?
    STINK EYE MOB #500
    2009 Subaru Impreza (I bought it new for my Mom)
    2004 Subaru WRX (Sold)
    2013 Subaru WRX Premium
    1996 Honda Civic Lx
    WRX genuine Face Ripping ACCELERATION!!!
    My Boston Beat Down Build Thread
    http://www.clubwrx.net/forums/builds...wrx-build.html
  17. #30
    Oct 2010
    Portland, OR
    Quote Originally Posted by TownLine500 View Post
    From the pics, I'd say the I/C pipe.
